1 - 8 of 8 Posts
2007 STS
Hello all, yesterday, I changed all of the spark plugs in my 2007 STS. Prior to changing them, my car hesitated while accelerating and decelerating. It has 126,000 miles (I purchased at 75K), so I'm overdue on a tune up.
When taking out the plugs 2,4, & 6, the ceramic part of the plug cracked and I believe some of the debris may have fallen into the cylinder in #4. I think this because after I put the new one in, when I removed it, there were small pieces of debris attached to the plug. All of the plugs fit in the cylinder and the ignition coils fit snugly as well. I replaced the coil on #2 because I cracked the housing while screwing it in.
I have had inconsistent results in getting the car to start. Sometimes it does, others it won't turn over. When it does, the runs "hard" and doesn't stay on long.
I don't know for sure it it is #4, but that was the only one that gave me any sort of trouble putting in (it tightened way too quickly the first few times I put it in).
I'm not a mechanic, but I can follow directions pretty well. Anyone have any suggestions to help me out? I can't get the car to a shop because I can't keep it running long enough to drive.
2005 STS
Buy or rent a bora-scope . Milwaukee and others make them. Remove sparkplugs and take a look. In saying, sometimes it starts and others it won't turn over, do you mean it won't crank? If only ceramic pieces went down, not likely anything in there now but powder. One bad cylinder should not stop the car from running. Something else is going on there. My advise, you saying "I'm not a mechanic", I would have it flat bedded to a reputable shop.
1 - 8 of 8 Posts
