CTS V wagon
What's the consensus on micro cracks in rotors? I picked my car up from the dealership for unrelated work and they gave me my car back with a fairly dramatic warning about my rotors being unsafe because of cracks. The cracks are very small (hardly visible) and largely limited to the center of the rotors. I track the car occasionally so they've no doubt been caused by heat cycles at the track. I'm not inclined to worry about it, but, for those of you who track your cars, when do you start thinking about replacing rotors? When the cracks are pervasive over the whole rotor face? Or do you base the decision to replace them on other factors, like warping or thinning?
'05 CTS-V
The little cracks are called heat checking. There's absolutely no need to worry about it at all. The only time I replace rotors is when they get to their minimum thickness.
Good info. Thanks.
2011 CTS-V A6 Sedan Modded :)
Unless the cracks get to the edge or you can catch a fingernail on them. Otherwise normal if you use your brakes hard.
2011 CTS-V Wagon-Raven Black, manual, satin graphite wheels
Another vote for nothing to worry about. Good to read you got your car back though :)
Also, from my experience tracking a Lightning, when a plain faced rotor (as opposed to a drilled one) actually cracks, it isn't something that propagates from the little heat checking you are talking about. It just suddenly and violently cracks. Standing next to the truck when a rotor fractured through at the track the noise it made was impossible to miss.
