1 - 19 of 19 Posts
2006 dts Cadillac 2000 sts balck on black
Ive had my 2000 sts for nearly 3 years now and it still rides well but a little on the harsh side.
Still have that enoying shimmy that ive tried to get rid off for the last 3 years.
Ok lets get to the point. I saw a 2006 DTS tonight with 100,000km's or 60,000 miles original owner husband passed away in March and wife is looking at downsizing to a smaller car.
Although cranky the woman warmed up to me after a talk and a rode test.
I think this is a standard dts , no shinny chrome wheels, no sun roof but does have turn signal in side mirrors & Ultrasonic parking assist . I didnt noticed but did the standard dts models come with heated seats ?
Its very clean and looks all original and drives way better and smoother than my 2000 sts.
Any major problems with the 2006 models ?
Do they all come standard with heated seats ? (I really like them for those cold winter days !)
One thing she did say that their was a small oil leak and that her dealer would take car of it or i could take care of it if i buy it. She didnt really know what caused or is causing this oil leak but the car still has warranty till october 2011. oIl leak common on these cars ????
Id like to also know if this model has the 4/6/8 cyl thing on the highway ?
Not buying a 4 cyl honda here but would the dts be a little better on gas than the 2000 sts ?
Thanks for you help !
Here is a pic of the car. P.S like the blue color but not a fan of light beige cream interiors but this one is clean !
1997 Mercury Grand Marquis
No cylinder deactivation. Yep they still leak oil. Valve covers from my personal experience with 2 2006s. Both have been the rear valve cover my current one leaks worse then my first. Heated seats are not standard and the car can be optioned pretty bare bones. Tire vibrations can also be an issue.
2006+ DTS don't do so well in MPGs as the older Devilles did. A non Performance one will get marginally better MPGs-L/100km because of the gearing.
I thought they had the 4 6 8 option like the impala ss 8cyl. 2006 models and above.
See my sig...
06 DTS Raven Black - 05 CTS-V Raven Black
I love my 2006, no leaks or issues. I have 40,000 miles on mine. What is she asking for it if you don't mind me asking?
1968 Eldorado
I get 24-25 mpg on the highway and 18 city. Combined avg is 21 if I don't drive too aggressive. These DTSs love to go! Far more comfortable than the STS or CTS. Extremely roomy back seat and I have plenty room up front for my 6'3" body.
Heated seats were optional. Look for the switches on the door panels if it has them. It may have the built in Cadillac remote start. Check the key fob for a circle symbol above the lock/unlock buttons. If it has the remote start you won't need the heated seat.
No real common problem areas. Some people have had valve cover leaks, but any car can have that. I think a flickering headlamp due to a bad ballast is another complaint I've read about on the 06s. I don't know if it a widespread issue. Overall the 06-12 DTS series has been far better than the previous generation Devilles.
I think you will find that everyone here will testify how much they love to drive their DTS.
91 Allante (gone), 06 SRX (gone)
The annoying shimmy is still present in some 06 and beyond DTSs and Lucernes, but not all. I felt it in some new and used vehicles I test drove when I was shopping.
As stated, check the upper front door panels for the heated / cooled seat switches. Heated seats were a requirement for my wife. Cooled seats were a requirement for me. The DTS seat heaters / coolers work great. My Lexus, not so much, at least in a driver's seat. (A common problem).
If you want a DTS w/ best MPG, avoid the performance edition. I would look for a Lux II / III.
1968 Eldorado
I think alot of the shimy issues are tire issues. I have the Michelins and the ride is smooth as glass.
From what I've read DTS owners don't like the Bridgestone and Continental tires for noise and/or vibration.
00 pearl DTS to 06 diamond DTS
I had the Continentals on my last 2000 dts and they were the best riding and quietest tire ive ever had. But I do know some that love the Michelin and that is what mine came with and I didn't like them at all. No shimmy on my 2006 dts, yet!!
2006 DTS LuxII
I pretty much agree with everything that's been said.Smoothest car I've ever owned.I did have the ballast problem and the valve cover leak,both were fixed under warranty.Since your still under warranty the leak should be covered with a small deductable.I've never known a cranky DTS owner,at least not on this forum,lol
Discussion Starter · #11 ·
$13,000 canadian. She would set up a date at the dealer to fix the problem.
Discussion Starter · #12 · (Edited)
When i drove it it was the smoothest car that ive rode in in a long time . Thanks for the info guys i will keep you guys updated. Still love the 2000 sts but she is getting tired.
Just saw another 2006 dts advertised at $8000 but it has 188,000km. Probaly worth the $5000 more for a mint dts with 88,000 km less.
Sedan de Ville, CTS
Northstar is a great engine, but it has had its growing pains over the years.
1. Early models had head gasket/head bolt problems.
2. They also had oil leaks from the 2 piece block.
3. Latest models had an oil pan leak at--guess what--about 60,000 miles.
Here is a simplistic description of the problem.
1. there is a thick aluminum gasket between the pan and the bottom of the block.
2. this gasket has a thin bead of rubber in the middle of the perimeter of this gasket.
3. After perhaps 60,000 miles or so, that rubber bead wears down. When that happens, you cannot tighten the bolts anymore because of the metal/alum gasket.
4. Result = oil leaks.
5. Typical dealer charge for this repair (which includes dropping the suspension of the vehicle) = $1800 circa.
6. From what I understand, the replacement gasket has the same design as the original. In other words, be prepared for another repair about 60,000 miles down the road.
Discussion Starter · #14 ·
Thanks ! I doubt that i will rack up another 60,000miles so if it is under warranty i think i will try and go for it.
Discussion Starter · #15 ·
Ok so do you guys think $11500 is a good deal ? Of course taxes and license extra. Im going in the morning to close the deal seems like the market for this type of car is not all that great right now !
Discussion Starter · #16 ·
Ok its bought as of today ! Nice looking car ! Think i got a decent deal !
Does lack some options that the sts has.
Discussion Starter · #19 ·
Ok had the oil leak problem fixed under warranty (valve cover leak) They said they had to lift the engine out ? Do they also have to take the fenders off the car to access the engine ? The reason why im asking is because one fender looks a little misaligned ? Might have been like that before the job i just dont remember their being just a lower gap from the door and fender.
1 - 19 of 19 Posts
