1 - 8 of 8 Posts
2004 CTS-V
I'm not sure of the maximum, but my ride height in the back is 27 1/4" and I think stock ride height is approx. 28 1/2". That would be a 1 1/4" drop for me. Someone with stock size wheels and tires (or maybe even 275s) could probably go another 1/4" lower for a total of 1 1/2" of lowering. I rub a little with the wider wheels/tires and I might even crank it up 1/4". But regardless, the car looks very badass and aggressive sitting anywhere near that low.
CTS-V
From my experience with GC kit and stock FG2 Nivomats, I couldn't go lower than WW's 1" spacer adjustment.
damn, I found this on the internet. Could this work for our nivomats meaning we could send our stock fe4's or fg2's back to the maker (sachs??) and have them: put in a Shock-Travel-Limiter (which is a thick disk type spacer that slips over the shocks center rod), thus effectively limiting the shocks upward travel. you will need to limit the downward travel of the rear wheels (in other words limit the total expanded length of the shock). From my understanding LPE achieves this with a new upper Shock-Mount-Relocation-Bracket that basically just has a deeper "hat", thus allowing the shock to sit deeper into the shock tower (effectively reducing the total downward travel of the rear wheel).
CTS-V
Sounds like it could work but using wildwhl's spacers is a tried and proven method. Better yet, just wait and get the KW coilovers that are soon to come out.
Discussion Starter · #7 ·
the ww method only works so so. It still pumps up and down slightly. Amd the drop could be a little more IMO. not bashing it all as its a genious mod and he helped us all out
CTS-V
Then that would explain why I had a clunk in the rear using the GC kit and WW spacers.
I'd say be the guinea pig with the AMD spacer.
1 - 8 of 8 Posts
