1 - 9 of 9 Posts
none
hey guys, i have been off this post for several weeks, borke my left wrist..
any how i had started my car yesterday and it said on navi " coolant low, check fluid" ??
so i read the manual and it says it doesnt take regular coolant?
1) where do i buy the fluid for this car, seems to be orange color? and what kind of coolant?
2) to fill the coolant, the only way is to fill it from the container located on the corner back right when u open your hood
3) i also opned this continer called " clutch resavoir" n it was empty, is something wrong, and if so what should i put in it?
also if any other fluid should i check while i will be doing oil change n coolant topping..
thank you.
oh yeah, best oil filter i should use , and where i can get it from?
'05 CTS-V, '00 SLS, 98 SLS, 89 Eldo, '80 Eldo
thank you.
Mike?????
You went through way too much trouble. Its all in the manual? :D
'05 CTS-V
thank you.
Where did they spell reservoir like that?
If you would look in your cars manual, it says to use DOT3 brake fluid. Something might be wrong because it shouldn't be empty. You might have a leak.
'06 Z06, '05 CTS-V 453rwhp/434rwtq (sold)
A lot of people end up with empty reservoirs and Bill says it is a mystery because there are never any leaks. The clutch fluid just disappears. :mystery:
'05 CTS-V
lol... hmmm
I guess it happened to me too. I just had to fill mine, I was wondering if I bought it like that and they didn't fill it up after a service or what.
I am checking every day just to be safe! ;)
Don't open it every day. You don't wanna get moisture in the fluid.
I've never had a problem with my clutch. My trick (learned it here) is that I freshen up the fluid every once in a while. Take the old fluid out of the reservoir, refill and drive around a bit. Do this a few times.
1 - 9 of 9 Posts
