I have been working on installing my mp112 kit on my 05 cts-v....getting to the final stages of assembly when I put the manifold assembly on the car I noticed that three of the injectors (blue with black tops) are able to be lifted about a 1/4 inch or less up out of their seats until they top out on the fuel rails and will not pop completely out....called magnuson and got the run around....anyone else notice their injectors are kinda loose no side to side wobble but up and down movement? just want to check before I pressurize the fuel system that this is common so I don't get fuel every where.....also with your kits did you only get one white wire to extend the wiring sensor harness when there is clearly two wires that need to be extended and if you cut it in half it will not reach to the proper local? I can easily find that gauge wire and add another to make the trip around the back of the super charger but just interested in your experiences....any help would be greatly appreciated.....I am finding comfort in this Mod Hell that I have created for myself.....thanks again Matt:bouncy:
