06CTS-V BOLT-ON,06JEEP TJ BUILT, 91 350SDL turbo(daily)
i made a free flow intake tube for my LPE intake and i have magnaflow cat back as soon as i put the intake in i got my engine light and i plugged in my dashhawk and it said low pressure from the MAF sensor then i cleared it and it didnt come back any ideas to what i should do ?
P
Guest
If it doesn't come back after several starts then you're OK. If it does, you might have hit one of the small pieces of metal inside the MAF and damaged it or you might have a bent pin in the connector.
2005 CTS-V, Black
Guess you didn't sell your V and get that bike?
05 Raven V
You had a temp vacuum leak on the intake, check connections and tighten accordingly.
