I am a curious engineer\computer scientist who once worked in automotive powertrain control systems (1990s).
My search on regenerative and friction brake blending produced 500 irrelevant hits on this forum, mostly folks lamenting on brake performance issues. A waste of time. My search on "regenerative and friction brake blending" on this forum produced exactly 0 hits. No time needed to waste.
The reason for this query has to do with my first (7,500 mile) service, where I am skeptical of the reporting on my brake pad thickness. All is good (I think) but the details made me scratch my head. Before anyone responds about dealers please don't. I've played that game and likely will do so again. I suppose I could remove the tires one by one and perform the measurement myself but I thought I'd try here first.
I am interested in learning more about the schema GM uses to blend regenerative and friction braking. Blending is a fairly common term to describe how the car goes from regenerative toward friction braking and back again. For example, when slowing down for a stop sign, if your foot is not on the brake pedal the car will decelerate using whatever level of regenerative braking you have set, until a point where it (the car) decides to engage the friction brake because a) the recovered energy is becoming too small, not enough to justify the efficiency gain, and\or b) you come to a complete stop and the friction brake kicks in. Yes, I know the paddle enters into this dynamic and I am aware of and understand the obvious corner cases of cold temperatures, SOC, etc. that are mentioned in the manual.
As a curious engineer, the details of how blending is determined and implemented is intriguing. So far I cannot tell if there is a transition or not (a good thing?) while driving until I get to an obvious point in diving (like a full stop). I've had exactly two (2) instances where I'm fairly certain that the friction brakes were engaged in situations not associated with the car coming to a complete stop. One was safety related in a parking lot (Kudos to GM).
Another way to ask a similar question (going back to dealer maintenance visits) is what "should" the normal friction brake wear on an EV (Lyriq) be compared to an ICE equivalent (size, weight) under normal driving conditions? This query on the web produced nothing of value, mostly hits from companies trying to sell something, and none from any EV forum.
My 2016 Buick Enclave, where I was easy on the brake pads, gave me 50,000+ on the fronts and about 100,000 on the rear pads. I found these same numbers on the web for EVs. Doesn't make sense to me, the braking technologies are very different.
What should I expect on my Lyriq under similar driving conditions? 100,000 on the front and 200,000 on the rears? That's why understanding the brake blending scheme is important to me.
Thanks for any constructive ideas or pointers.
