Has anyone tried to jack up a 2024 Lyriq? If, so where do you set the jack and jacks stands?
Considering the bottom of the Lyriq is mostly a large framed battery bank, this makes sense. Although when driving in certain remote areas where carrying a spare tire would be beneficial, having two scissor jacks onboard to lift one side of the vehicle shouldn't be a big deal. That sure would beat pushing the OnStar button, then waiting for... who knows how long.From what I've heard from a GM tech you have to raise one side at a time not just a corner.
The lift points are fixed at 48-50 inches, so the load would be distributed differently on the floor. The distance between the wheel wells is about 86", so the TLX would reach within 3" of the wheel well at each end. While the TL would give an extra size inches distance from the end of the lift to the wheel well. That's a nice extra working distance, and as both lifts are specified for 7000 lbs, either would work. The frame of the lift is at the end of it, so its a real difference in working distance behind the wheel. I am not sure this is a big deal... I have those accessory rocker lights in the rocker near the front wheel and they are about six inches long.The Lyriq has a wheel base of 122" so the QJ 7000TLX should fit easily between the tires. Perhaps QJ recommended the longer TLX because it distributes the load better than the shorter TL model.
B
Thanks for this useful summary. I have a few remaining questions:Well, I've now watched way too many YouTube videos and read most of the manual. There are a number of detailed steps in the setup, so this is project where you need to closely follow the manual. The worst YouTube video dropped his car when he released only one side and lowered without noticing the other side was still locked in the raised position. Both he and the car survived, but clearly paying attention is a must. Except for as guided by the manual during initial bleeding, another one is to not raise QJ with no car on the jack. You can used them side ways in some situations which might come in handy. If you use the liquid thread seal during initial setup, you are down for 24 hours to let it cure, so for those comfortable with teflon tape, that lets you use it right away (lots of cautions about how to apply the tape in the manual and a QJ video). Lastly, you can get some additional height with pads like the optional QJ lift pads, but there must be some extension below the vehicle or it will not be able to lift it. Finally, QJ says you must use an additional set of jacks under the vehicle to work there, many YouTubers don't seem to do that. I think I would, but as noted above, there is little reason for most jobs be working directly under LYRIQ.
I assume you mean to move the QJ around on the floor by using the furniture dolly? I made my own furniture dolly for another purpose with 2x4s, some strong wheels from HD, and some nice big lag bolts. I might tailor make either a pair, or one, to mount the QJ units, which must be heavy to necessitate the use of a dolly. I will see if I can find the "small wheels" vids. My QJ is arriving tomorrow.Just a couple of quick after notes. After raising the price back up to retail, tonight July 16, 2024, Home Depot is down to $1,475, down from the previous sale price of $1,559. If by chance you bought a 7000TL from HD in the last couple of days, call customer service. They will do a small refund. Of course if you bought at retail, that's a big refund.
There are a bunch of YouTube videos on how to add small wheels which might make sense if you plan to leave QJ on the floor. Tearing down my setup this afternoon, I set them one at a time on a furniture dolly, which worked surprisingly well. Also, at least after the first lift, there was virtually no compression of the pinch weld block, just a small mark at the bottom of the channel. The pinch weld block is not high enough, so I used it on top of the supplied small hard rubber block.
I keep watching YouTube videos about the QuickJack, now particularly looking out for clearances around the various vehicles for which they are used. I saw several where the clearances were virtually nil. One guy was rushing back and forth with his car pressed almost right against the rear wall of the garage, while its nose was moving closer and closer to his garage door during the lift. It ended up with it pressed within 2" of his door. I have seen many with side clearances around the 2-3 ft range.No sympathy required
- I have now taken delivery of my 7000 TL, and I am taking it slowly with the install. My first surprise was something I should have caught up front, and that is what QuickJack calls "required" clearances around the vehicle.
- T....
- Hopefully, I can install and lift now after thinking through ....
No question that you need to be sure to have the lock rods in the right position when operating the QJ. I am 99% certain this is what undid these people who had a disaster.I found the QJ video on bleeding the hydraulic lines helpful. I don't think the paper manual talks about raising one side of each jack for bleeding: The Official QuickJack Setup Tutorial Part 4 at 4:00
The few fail - crashed videos seem to mostly be from one side not being properly locked. It is surprising how relatively small the locking mechanism is, but that is it, the end of the lock arm and lock nub. Once raised and locked, QJ is only supported by the mechanical locking bars at the stops. QJ has a video where they overload the jacks, so it would seem that the stops are well enough engineered. Hopefully the QJ QA program catches safety related manufacturing defects, but I would still visually inspect both locking stops for any obvious manufacturing defects.
It is possible that one or more of the failed videos did not follow the lock instructions:
After both side click on passing the stop, it still takes an affirmative down press to lock both sides (step 14. above). Is there a link for the failed video with the crushed disks?
