Has anyone tried to jack up a 2024 Lyriq? If, so where do you set the jack and jacks stands?
This is what you will want to get for the Lyriq: QuickJack 7000TLWell that's a deal killer right there. I can't swap winter and summer tires myself? That's twice a year (minimum) that I have to bring it to a dealer to do something I've been doing for decades.
I did some pixel maths with that image in the link for the Lyriq, the lift points are under that 66" so it'd work.
OK, I got down on the ground and measured the distance between the lift points. They are 48" on center.Interesting. How close do you get to 66"?
That's really good. Thanks for doing that.OK, I got down on the ground and measured the distance between the lift points. They are 48" on center.
I presume that the concern about using a floor jack is related to twisting of the battery pack. IOW, if you could jack both lift points on one side (to tilt the car), you should be able to get the vehicle up high enough to get sufficient clearance to remove the wheels. I honestly wouldn't see that as any worse than driving across an embankment.I predict many people will damage their batteries due to the fact people don't bother to read the manual. I wonder if someone will make some sort of adapter for floor jacks?
Thanks for looking. I wonder if the QuickJack people know the answers to these types of questions?I got up under my Lyriq this evening to see where the lifting areas are, expecting to see the typically doubled up metal where a tire jack would normally go. Turns out there's nothing like that on the Lyriq. Instead there are four rectangular holes, two on each side, about 6"x3", about 3" deep. Looking up inside these rectangular holes I'm pretty sure I saw the frame of the vehicle. It's a safe bet that GM makes lifting insert for these four holes, and as othes mentioned its probably wise to lift the Lyriq at all four lifting points at the same time so as not to twist the battery compartment. Anyone know if lifting inserts are available for the Lyriq (thru GM or after-market?). A set of 4 lift inserts will be needed for a QJ or other type of lift.
S
