Exclusive World Premier here I think - charging a Lyriq at a Tesla SuperCharger (with the Magic Dock). It isn't pretty, but it can be done...
Doing it this way (perpendicular) requires lining everything up just right, and pulling over the curb without hitting the bollard. You'd want to do this at the right-most stall in order to not block any other Tesla's. I couldn't do that in this case as there was a vehicle already there. This is barely doable - has to be perfect for enough cord length, and even that is really torquing the cable at a right angle at the connector.
The much better way is to pull in sideways - parallel to the stall / curb. If you do this on the left-most stall, you won't block any other stalls. Not all SuperCharger stations allow you to pull like this, some perhaps could be done at a 45 degree angle, but would block the other stall a bit.
