N0DIH said:
Is there that much performance gain with the 1.6's vs 1.5's on the stock cam?
Or is it really best to go with a cam like the HT383 cam or a custom grind?
My thoughts on a new cam, I would go for a .470/.470 lift, with a LC of 107, duration of 201 intake, 206 exhaust @ 0.050".
Maybe a little more duration if I felt the top end of the rpm range could tolerate it. I think if anything it needs more breathing, but how much to not sacrifice low end.
Check this link for other cam data.
http://www.fierolt1.com/lt1_camdata.htm
As you can see, the stock LT1 cam with 1.5 rockers pushes .447/.459 and .477/.490 with 1.6 rockers. That's a significant gain IMO to switch to 1.6 rockers.
I run the 845 cam with 1.5 rockers, it's listed in the link I posted. Lift is .488/.509 with the 1.5s. I could have easily got more lift out of the setup (putting me at .521/.543) but there are two things to consider here:
#1.) With stock heads, will they actually flow enough to take advantage of the extra lift? Possibly - but borderline most likely on the exhaust side without any headwork (porting).
#2.) On the cast iron heads, they utilize pressed-in rocker arm studs (as opposed to screw-in studs) which have limitations on how much lift they can handle before snapping or being pulled out. I kept my heads stock, so decided that .543" lift on the exhaust side made me uncomfortable with pressed-in studs. So in order to not risk a disaster like stud breakage, I opted for .509 lift with the 1.5 rockers.
As far as your cam selection, it is NOT worth the money and time to swap cams if all you're going with is .470/.470. You can gain that or better just by throwing on 1.6 rockers and the stock cam. And for duration, the stock cam is greater than 201/206.......
And LSA at 107 is weird...... for emssions testing 112 and 114 LSA usually are safe I believe.
You may want to rethink that choice!
Honestly, the stock cam is really a great cam for low end torque. The F-body has many more choices than we do for cams since weight is not such a factor - they don't require the torque we do in 4000+ pound cars.
Matching the right bolt-ons to stock internal engines can produce awesome results..... there are stock-internal Caprice/Impalas in the 12 second quarter mile time bracket with just bolt-ons and no nitrous, believe it or not. :stirpot:
I'll drop you an email so you contact me off-site.
