2004 ctsv
Does anyone know how tall the LS7 and CTS-v slaves are? Reason I'm asking is after installing the Spec 2 Cluch and Flywheel its hard to shift into gear. System been bled several times. I think that the Spec spacer that came with the kit may be a little too short to work with the V slave. The Spec spacer is a little more than 3/4 inch. If anyone has any idea what the sizes are on the Katech and Tpis spacer pls let me know.
04 CTS-V with a little hp persuasion device
I can tell you the spacer needed for the LS7 flywheel and pressure plate is .950". I know that doesn't help much but its what I got! lol
2006 CTS-V
Interested to see what you find out, as I'm in the market for a clutch. For now my plan is to follow the path 154 has blazed.
Well it worked fine before I had the maggie. It wasn't much longer after I installed the additional hp that I had clutch problems. If you dont plan on much more power you may be fine.
