We now have the new Meziere electric water pumps in stock for the LS2 motors!
The LS1 pumps will not fit the LS2 motor. Meziere had to make some changes so they will now fit all of the LSx motors. They put a relief in back of the pump body and milled a pocket to clear the LS2 throttlebody. The pump now says "LS" insteaad of "LS1" but the neck will continue to say "LS1" for awhile. A few of the new design made it out of the manufacturer saying LS1 on the body. Maybe they will be collector's items :)
These pumps have been tested at the track, on the dyno and most importantly, during street driving. They have allowed engines to run cooler at low speeds and gain high end horsepower. In addition to the released power, you get to keep all of your factory accessories. Taking quality to the extreme, the WP319 series pumps feature a dual bearing belt idler, billet parts throughout, and a “weather-tite” electrical connection. The pump is backed by a two-year warranty.
Features:
Purpose built for street use – 3000+ hour life expectancy.
Fully polished or anodized in your choice of 4 colors (Black,Blue,Red,Natural).
Chrome upgrade available.
55 GPM free flowing rating.
All stainless steel hardware included.
Heater and bypass provisions.
Light weight. Complete standard LS-1 unit weighs only 14.9 pounds!
Stainless steel large diameter main shaft with high performance ceramic seal.
Inlet fitting supplied to match stock configuration.
Easy install - truly a "bolt-on" pump.
Full two year warranty - the best in the business!
Finishing The System:
This pump is supplied complete with gaskets and hardware, complete and ready to bolt on. The only additional item you will need is a standard Chevrolet thermostat if you desire to use one. It will install behind the exit fitting located above the idler pulley.
Amperage draw:
Under normal use the pump will draw 11-12 amps.
Overall Height Dimension:
The standard pump is 7.88" long from the mounting surface to the tip of the pump.
Pump Weight:
This application weighs 14.9 lbs.
We have an introductory of $514.99. This includes a free thermostat and free ground shipping in the 48 states. This price applies to the black pumps (most popular) along with blue, red, natural, purple and polished. Add $110. for chrome.
Orders can be placed online or by calling 1-877-482-9763. This pricing will be good through June 4th.
Have a good day!
BANK OWNED!! CTSV & EXT
you have to cut quite a bit off the fan shroud. I trimmed the tips of the pass side blade down a little to.
Here are some pics of mine. This is an LS6 by the way.
