I've never done this before, but need to lower the back of the cradle 3 inches. I see 4 cradle bolts in the back - so that part is simple.
Do I need to disconnect anything before doing this?
Can I loosen/remove the 4 rear bolts only - or do I need to loosen front to prevent bending the cradle?
Can I support the cradle with a single jack (if I drive up on ramps)? Is that a safe way to lower the cradle?
(In case it matters, I need to remove B1S1 O2 sensor which sits on top of the rear exhaust manifold)
