1 - 20 of 26 Posts
Hello to all you experts. I'm a brand new Cadillac owner so I need some expert advice. Just purchased a '95 DeVille, with 4.9 Engine a few weeks ago. About 81kMiles. Clean car, well maintained and not known to have been abused by prior owner. From day 1, I noticed that when I start off from a traffic light (i.e., from a dead stop) and try to go for a slow, smooth, easy build up of city street speeds, there is a momentary "dip" or hesitation, then the engine sort of catches up with itself and speed increases. By the sound of it, engine RPM does not actually slow down, rather, it takes a bit to react to gas pedal position. It almost feels like the result of a small vacuum leak in a regular carbourated engine, but this engine is throttle body fuel injected not normally carbourated. The car has plenty of pep and can do a jack rabbit start if I press down briskly on the gas pedal, and drives smoothly otherwise at all speeds. Any thoughts please? BTW, an acquaintance of mine said he has driven Cadillacs all his life and they are "just that way."
Thanks for any response.
2005 CTS-V, 1994 Infiniti Q45
Has the air filter been checked?? It could also be a clogged injector, dirty TB, fuel filter, etc......
But, they will be that way, to a certain degree....... A big heavy car like this isnt going to have the throttle response of a little sport compact or whatever......
That is NOT the way they're supposed to be. You do have a problem causing it. There are MANY things that can cause your issue so it may take some looking. Mainly, it will take a good patient mechanic. A thorough tune-up and general inspection should reveal the problem. And yes, it could even be an intake leak.
Discussion Starter · #4 ·
Air filter is not new but pretty clean (will change it nevertheless). Have good acceleration and smooth highway speed changes so I don't think it looks like a clogged fuel filter. A mechanic used one of those "injector cleaner" liquid kits, some right in the throttle body and some in the tank. Seemed to help just a bit for a short while (maybe just wishful thinking). Any thoughts about using that kind of stuff? Any particular kind ?
When mechanic looked at it (see my reply to "Elweso") he said that there were no codes indicating any problems and even said the plugs didn't have to be changed. (He is a rare breed - not recommending work that he feels doesn't have to be done.) I am more inclined to believe it is a vacuum (intake) leak although I might put another can of "injector cleaner" through the system. My experience (years ago on my old Chrisler Imperial 440 Cu in) leads me to think that with the high underhood temps, especially here in Florida, those rubber/neoprene hose ends can get hard and brittle over metal fittings and loose some vacuum over time. Would you agree that would be a good place to start? What should a normal idle vacuum reading be, 29" to 30" ? (I don't have any shop manuals on the car or the engine).
2003 Cadillac DeVille
Dudes hes having the same problem I am! Low idle hesitation! Same motor too!
01 frontier , 89 Shelby CSX vnt
" those rubber/neoprene hose ends can get hard and brittle over metal fittings and loose some vacuum over time."
i dont have the problem myself , but i did notice that the vaccum line from the thottle plates thats about 4 inches long has been replaced on mine ....
i will see if i have a vaccum gauge out in the garage and take a reading of my vaccum and post it in this thread
i will see if i have a vaccum gauge out in the garage and take a reading of my vaccum and post it in this thread[/QUOTE]
Thanks for the tip. I'll look for that line first and see what condition its in. Please post your vacuum reading (and where you tapped in to a vacuum source) so I have something to go by. BTW, something that makes me feel even more that its a vacuum leak is that at a cold engine start-up, for a few short minutes (until the engine reaches normal operating temp) the hesitation is not bad at all. I would think that the slightly higher rpm and/or richer mixture at cold idle tends to compensate for a small vacuum leak. Once warmed up though, the hesitation is back.
Clean the EGR tubes
I had exactly the same symptoms and found a thread at caddyinfo.com (http://caddymb.netgetgoing.com/ use the searchable archives)on cleaning the EGR tubes and throttle body, and it was right on.Not only ran like new, but added gas mileage back to what it got years ago!
Discussion Starter · #10 ·
Re: Clean the EGR tubes
Thatr sounds like a winner! As soon as I can get the car back from my wife, I'll give it a try. But,....this may take a few days before I have access (she just loves the car).
Frank
Take off the TB, and reach inside the hole that the TB hooks to (plenum), and get some rags and TB cleaner....... It will make a world of difference!!!
Discussion Starter · #12 ·
That sounds like more than an hour's work, which is ok by me but not necessarily ok by the lady of the house. Its almost impossible to get posession long enough to for the engine to cool down so I can work on it. Will try the vacuum lines and egr valve options first, then the TB removal etc., if needed. Thanks for the tip.
Frank H
TB removal isnt really that hard...... Maybe 20 mins to get it off, and then however long it take you to clean/replace......
Might as well do it all and not have to worry about it!!!
Discussion Starter · #14 ·
The only issue is getting the car alone to myself long enough. You know who, has claimed the car for herself. I'll have to wait a bit 'til she goes away for a weekend to visit the grandkids then I'l be able to muck around under the hood to my hearts content without getting "The Look".
If you take off that TB, I promise you the car wont be going anywhere!!! :D
That could also cause other, non-TB related strife.....
Just make sure you clean out that plenum as best you can before you put the TB back on...... You may have to rig up a rag on a dowel of some sort, but it will be worth it...... it will make a difference of night and day!!!!
Discussion Starter · #16 ·
Years ago I rebuilt some carbourators (Carter 4160s as I recall) but I've never handled a TB. Is there a gasket between the TB and the Plenum that I need to replace just because I removed the TB? Are there gasket/seal kits I need to or should get ?
You will need a gasket from the TB to plenum...... They are paper, and if they rip your screwed.... Sometimes you may not need it, but better safe then sorry..... Thats about it for TB removal....
Discussion Starter · #18 ·
I decided to just take a look under the air cleaner inlet thing to get the lay of the land so to speak. I jiggled a few tubes a bit an lo and behold, there is a small diameter steel tube that feeds vacuum into the transmission (probably something to do with load sensing for shift points). This tube is about 1/8" dia. at most. The upper end fits into another steel tube comming out of the TB. The end of the 'goes into" tube is flared, BUT the only thing holding it in place and (theretically sealing the connection) is a piece of rubber tubing over both tubes, about 1" long! No clamps, spring locks, nothing, nada, nil... even though the diameter of the tubes are different (remember, one goes into the other). It was stiff but could be turned. So.... I am thinking this may be the source of the vacuum leak and possibly have something to do with a bit of the slight harshness of the 1 - 2 upshift. Its worth a try to at least replace this little piece of rubber hose before doing much else. It certainly can't hurt. When I'm ready to tackle the TB removal, I'll get the gasket (just in case). Is this a dealer only item or can I get it at an auto parts place? The Cadillac parts department closes at 5PM and they are not open on weekends, so getting parts from them is problematic. Look forward to any comments you may have.
Im not sure what you are saying...... so post a picture of this thing yo are talking about.......
Also... I think you could get the gasket at an autoparts store..... might as well check, and if not, cadillac dealer is the next best......
If you want to get it done and dont want to go to any dealer, you could get that gasket material and make your own make shift one until the dealer is open.......
im getting ready to take my TB off and do my EGR , got the gasket at NAPA for like 5 bucks and the EGR for 65 (gasket included) , found the vaccum gauge today but i wont be able to look at the car till tomorrow (damned deed restrictions)
fixed my oil leaks today too , seems there are two fittings for pipes that go into the oil filter got one full turn out of boath , might be something else to look at while your in there to keep you driveway clean , you know how ladys get when things start marking there territory around the house
1 - 20 of 26 Posts
