Seville STS 2001, Eldorado 1997
About a week ago, the car would start, then RPM would fall and car would stall. I removed IAC motor and throttle body and cleaned very well with throttle body cleaner. I used just cloth with the spray. I removed the rubber channel up till TB (where the TB flapper becomes visible). After I cleaned, car worked fine. Today again got same problem when car will die immediately after starting (RPM falls). Again cleaned TB and IAC this time with TB cleaner spray and used toothbrush and cloth. Car is starting but RPM is about 500 and getting code P0506 Cadillac - Idle Speed Control System RPM Lower Than Expected
I did not remove TB. I was quite sure that I cleaned very well. Any ideas what to check. Could there be any vacuum leak. I checked physically and could not notice any vacuum pipe leaks. Any ideas please
John
Re: Low RPM, P0506 Cadillac STS 2001
Did you spray TB cleaner through the IAC passages?
Other than that, all I can think of is maybe a failing IAC valve.
2001 STS
I had the same trouble with my 2001 STS, kept stalling unless I kept my foot on the accelerator. I replaced my IAC and no problem. It was the easiest part I had to replace.
2001STSCADDY
Thank you Ranger and 2001STSCADDY. I sprayed TB cleaner in IAC path and put my finger with cloth and cleaned very well. I think that it is bad IAC part. I am going to replace it and share outcome.
John
2002 STS, 2005 CTS 3.6
Did you take the IAC apart? Easy fix, save your money for something else! Remove the IAC and (twist out) the plunger and spring, clean everything good, it will likely have crud in there. Then screw it back in all the way tight. Reinstall, fire it up and drive around a bit and clear your codes. This normally cures the idle problems relating to those DTC codes as the plunger tends to turn out over time and block the idle air holes in the throttle body.
I replaced IAC valve. Problem resolved. I bought new one for less than $10 from ebay. Thank you all for your feedback.
Anwer
Less than ten dollars?? I hope it was a used AC Delco, and not no name garbage.
