1996 Seville SLS
hello, i was wonderin if it is somehow possible to make the low beams and high beams go on when the high beams are switched on??? i really dont like that when u need the extra lighting and turn on the high beams the low beams go off anyway into rewiring the wires?? thank you in advance!!
My question would be, is this good for the bulb? With both beams on for a consistant amount of time, there would be alot more heat being generated in the bulb by both filaments.
1994 Sedan Deville
2003 STS w/BoseNav, 1993 Deville, 1985 Deville
You might want to be careful with this mod. The connectors may not be rated to handle that much current for an extended period. You could wind up with melted connectors, hot wiring, or even a fire. Consider upgrading the wiring and/or connectors.
Or...add driving lights.
