2002 DTS
Just bought this DTS and the passenger rear door panel will not stay on. Turns out...every push pin is broken the panel is cracked all over. Anyone know where I might be able to find one? The color is light tan on the bottom and a darker tan or brown on the top.
2011 DTS Platinum
Not trying to be rude... but this is the 2006 to 2012 DTS section...
You would probably have better luck posting the question in the DEVILLE section...
Texas Jim
1997 Mercury Grand Marquis
I'd try to repair it with an epoxy. I had to do that with one of my Town Cars it worked pretty good. You can get those push trees at any auto part shop.
04 Deville, 11 DTS Premium, 00 Deville (sold), 02 Deville (sold)
The white plastic retainers with the foam gasket are part# 25696693.
Most cracked panels can be repaired with epoxy. If you need the entire door panel check with your local junk yard or contact www.cadillacheaven.com for pricing on a used panel.
