1 - 19 of 19 Posts
with the rising cost of gas, anyone know where to get a locking gas cap,, also will the 04 locking cap fit on the 2006 ext. most peoples books i have been talking to only go to 2004 p.s. i read here the dealer wanted 100 bucks for a regular cap that means 500 plus for a lock in it. :) hee hee. thanks in advance..
1989 Fleetwood FWD / 2000 ETC / 2000 STS / 2006 STS V-8 1SF RWD
Hello...
May I ask why you are interested in a locking cap?
Is it just to make sure that the cap is securely fastened?
If so, a locking cap will solve that problem.
If you are worried about someone siphoning gas from your tank, do not worry, as the tank has a built-in anti-siphoning valve to prevent this. No one, not even you, can siphon gas from this car.
There are aftermarket caps that lock. Just be sure that it is an approved cap for your vehicle as this can have an effect on emission controls...and your "check engine" light!
Post back your solution.
Discussion Starter · #6 ·
those are really cool looking, but i think 4 me i just need a locking cap that fits properly, and every where i look seems to have nothing available or no info what so ever will the 05 fit the o6 it has no threads on the 06 only a couple ridges in almost triangle shape. ive searched the web bigtime with 0 results. and im afraid to call a cad. dealer. although if they have one i guess il just have to take it in the shorts. just wonder if any one knows, bout em or is a avalanche cap gonna work or whatever. i just park a few days at a time when im out on my boat. and kids have been known to screw around with cars at the lake i go to.:alchi:
Escalade EXT
YOu can buy a locking gas cap from any autzone or car store, but you may get an error code on your dash telling you that fuel is leaking. It showed up with me after having the gas cap on for abour a year. I dont know why this happens but it happened but it also happened with several other people on thise site. Also the locking gas cap I bought costed around 10-15 dollars. and is much easier to put on then the fancy ones with a button in the front. plus I dont like the way they look anyways.
White diamond '04 Escalade AWD
I tried the GM parts direct locking cap and got the 'vapor leak / check engine' message within 10 miles. The problem is that the part is made for the 2WD 2004 Escalade and I have the 2004 AWD Escalade (6.0L engine).
Problem solved? I have had no problems with the 'Stant 10511 - Regular Locking Fuel Cap: W/O Threaded Filler Neck' so far (it's been about 2 weeks.) I bought it from Advance Autoparts. The clerk said it's the same cap for the Avalanche.
-E
Discussion Starter · #14 ·
i just had my buddy behind my store get me, a 11551 he says thats the new number for the 10551 locking threadless, staNT. the cost was 8.50 i get wholesale he owns a econo lube and tune behind my store. il be driving it 2nite about 40 miles so il let ya know what occurs.
The Stant 11511 is the same cap as the 10511. The 11511 just comes in a box and the 10511 in shrink-wrap. I asked Advance Autoparts the same thing.
-E
1 - 19 of 19 Posts
