Two years ago I replaced both rear door lock actuators, they started to act up intermittently around the same time and thanks to this site the problem was easily diagnosed and corrected. They've worked great ever since. Then a few months ago the front passenger door started doing the same thing, and I replaced that actuator as well, and again problem solved.
But now the front passenger door is again not opening from the outside. It's not the cold or ice, the car is garage kept. I don't believe it's the micro switches, as with my passive entry enabled, I can hear the other doors unlock whenever I pull on the outside handle. And the door opens fine using the inside handle. It just won't open from the outside.
So does the actuator need replaced again? Or could it be something else?
