1 - 20 of 27 Posts
2009 CTS-V, 545 RWHP 591 TQ
I just thought I would share this video. V&P is a local shop here in Kansas City and he just finished a CTS-V coupe twin turbo, and it retains the factory blower.
Anyways, I just figured you all would like to see some other options to make high hp for these cars (made 731 RWHP). Enjoy the video
2009 CTS-V , 2010 SRX 2.8T
Simple is good. Having a blower & turbo's sounds really cool but would seem like a maintenance / troubleshooting nightmare
2011 CTS-V manual
retains the factory blower? so its a TT SC V8? guess i thought when they made the Vs TT that the turbos was replacing the blower.
2011 CTS-V Sedan
REALLY doubt that they are running twin turbos with the factory supercharger still functional, that doesn't add up.
Joe
2011 "BD" CTS-V, 2010 CTS-V (Traded), 2007 Escalde (Sold)
"Forcing air" on top of "forced air"???
1959 Cadillac, 1980 Cadillac,Former 2005 CTS-V; now a 2009 V
That's standard on modded Fort GTs, i don't see why it doesn't add up
Joe
It is running both, it's called compound boost. You eliminate the turbo lag so the tq down low is crazy, yet you get the top end benifit from the turbos. I've seen it on other cars (Ford GT, GT 500, etc.).
It is a crazy concept though. I'm curious to see how durable/reliable it will be.
Banned
cts-v
there is a guy here in town with a new saleen tt sc slaters did it...i've seen it done before.... i just think its over kill
2011 CTS-V Sedan
I have seen it done, and am familiar with turbos feeding superchargers, even in multiple stages. What I was trying to get across was that they've put twin turbos in...ok great...but if they were large enough to HAVE lag (and thus "need" the orig blower) the car should be making CRAZY power, and if they are small enough to not lag (which would account for the low power), then it doesn't seem like they would "need" the orig. blower.
Unless it's just for the novelty of it...?
Joe
Premium Member
1975 Seville; 2004 CTS V; 2011 CTS V Coupe
Hell Yes!!! One of the first Toyota MR2's was Super Charged and Turbo Charged - from the factory. :sneaky:
Each is designed to work over low RPM vs high RPM power ranges. Excellent concept. The Turbo's are most effective once engine RPM is high; a purely logical balance of power enhancement. This is an old idea to take advantage of each boost application to maximize power over the entire RPM Range.
Power plant Emergency and Train Engine Diesels use a Super Charger at startup and transfer boost to Twin Turbo Chargers for a very high specific power output to maximize efficiency. Also, quite durable!
2013 6MT V wagon, OBM, 2009 silver V sedan (traded)
Great concept, and great song!
("The Distance" by Cake, from their 1996 album "Fashion Nugget")
<-----"Hulk" 2000-2012...He will always be missed :-(
Very cool, though I am reminded of the quote: 'The more they over think the plumbing, the easier it is to stop up the drain'.
2011 Thunder Gray CTS-V Coupe
KCMO or KCK?
I'm trying to tint my tails just like that, anyone know how they did it? Everyone around here seems perplexed with the idea..
Banned
2009 CTS-V, 2007 Z06
I think this is the shop that did it on a sedan, and then we never heard about it. Glad it worked for them. It's a great idea, but I would have put bigger turbos for more hp. Anyone have any idea on the specifics?
King, you can tint them like that, any guy that can wrap a car can wrap the lights. or you can paint them, which is what I did. If you do not paint them you will have to have one seam on it and if the tinter is good then he can make it very hidden, however it's still easily visible from 2 feet. You can paint like that with a gloss black, or you can matte black them like I did. Any body shop should know how to do it.
Discussion Starter #15
KCMO or KCK?
If you are in Kansas Jeremy at house of boost in lenexa can tint your tails for you.
Tuner car fanatic..there all good!
What do ya'll think of the tail pipes?
I like them even though it does take on the "non" V CTS Coupe look.
Banned
personally I would not do the compound boost, just put a big turbo in with the right specs and forge your engine, you will smoke all the compound boost with just the stock blower :)
09 Silver V 06 Silver Z06
yes they did one of these on ls1tech as well for a black sedan last year then were trying to sell the kit on ebay
A TT+SC set up will have a slight advantage over a properly sized TT-only setup at the lower part of the rev range. However, this advantage is small for the price you have to "pay" in the higher rpm range where the TT-only's will be MUCH faster. The issue is that the SC draw a LOT of HP at the high end and then you have the added heat of compounded compression. The TT+SC is cool to talk about and the shop doesn't have to worry about greating a plenum to replace the SC. The net net is that for virtually any kind of spirited driving or track time (1/4mile runs may be only exception), a TT-only set-up is simply a superior solution.
1 - 20 of 27 Posts
