Lots of parts needed to convert to LS1 or LS6
oil pan
oil pick up tube
spark plug wires (1 TO 8)
accel. cables
motor mounts (2x)
engine cover with V8 logo on it
air cleaner and ducting
alternator
starter
fuel lines
radiator with shroud and radiator fans (2x)
coolant reservoir
Bosch electric coolant circulation pump
oil/transmission cooler with fan
oil cooler thermostat
HD front brake calipers
HD front brake rotors
HD rear calipers
HD rear rotors
ABS units
brake lines
3.08 HD differential
auto trans shifter assembly
driveshaft
horns
AC lines
V8 door sill plates
transmission mount
muffler
rear shocks
flex plate
many heat shields
most fasteners needed
Can send pics let me know, looking to get $1000.00 for the lot.
It would be worth it for the brake upgrade alone.
oil pan
oil pick up tube
accel. cables
motor mounts (2x)
alternator
starter
fuel lines
coolant reservoir
HD rear calipers
HD rear rotors
ABS units
brake lines
driveshaft
horns
AC lines
V8 door sill plates
transmission mount
muffler
rear shocks
flex plate
many heat shields
