05 Maggied V Black/Black
It needs two solenoids and is not available off the shelf. You can jury rig one, but the best bet is Katech.
Solenoid traps/locks fluid in front brake lines so that, after you release the brakes, you can smoke (warm up) the rear tires without the rear brakes applied, while the front brakes keep the car from moving. Mostly used for drag racing. Well, unless you just like to smoke your tires. Then there for you, as well.
