My lights on my 07 CTS keep coming on in the middle of the night all by themselves has anybody had this problem
2007 CTS 3.6 >129k miles
I have not heard of this problem on a CTS but had a different car many years ago with a similar issue. After exploring various connections I found that the switch (turn signal lever) was worn and shorting out. Replacing it solved the problem.
06 CTS Sport/Luxury package
I wonder if it thinks the key has been removed from the ignition.
I know there is a setting in the radio. You can adjust it so that when you remove the key, the lights remain off.
As a technician, I would disable that feature and keep an eye on it. If they remain off for several nights. Then I would replace the ignition switch. If the headlights continues to randomly turn on, then the issue is else where.
KOT
