1 - 13 of 13 Posts
Wanting to remove both rear wheels for cleaning and Zaino, Can I lift the V from the Rear Diff or is there anothe point where I can safely raise the entire rear of the car?
2004 CTSV
DON'T USE THE DIFFERENTIAL FOR LIFTING
I do it on my truck but not the V
Either build a cross brace or use two floor lifts (that's what I do)
See you in the funny papers
04 CTS-V, 05 STS, 07 SRX- All sold :(
Put a stack of wood 2x4's on your jack and use the rear subframe one either side of the diff as a jacking point. The jacking puck will be below the diff, but neither it or the wood will contact it. Once it's up, support with jackstands and let down the jack.
crushing Vs with my Wurm
2013 GT500 - 700+ HP
NO NO NO NO NO NO NO NO NO!!!!!! STRICTLY VERBOTEN!!!!!
No lifting of the rear by the diff......
Just do one side at a time....thats what I do when I zaino....
F
what the hell are you guys zainoing??? the undercarriage??? I can always seem to hit everything with all four wheels on the ground :confused:
I do the insides of the wheel.....not sure what the other fella does.
F
Discussion Starter #10
Thanks fellas, After the first response I'd started on the right and will move the left tomorrow.
I didn't want to have to explain that to a Caddy Service dept.
Niko, I'm 6'3" there's only so much ground work one can take. I was cleaning wells and wheels. It's so much easier with the wheel off. I did the front in a jiffy, cause I lifted from the middle.
LS6 CTS-V
Reviving an old thread but am still interested in hearing more thoughts. I hate jacking up one side then the other. Would much rather prefer jacking up the rear (after the front is secure of course) from a single spot.
I jacked on the diff in my old ‘stang but am reluctant to jack on the V’s diff. For those of you using 2x4 along the subframe - aren’t you nervous about the 2x4’s being used to span cracking under load?
1 - 13 of 13 Posts
