1 - 19 of 19 Posts
Escalade EXT
My license plate lamps stoped working is there a fuse for this somewhere or has anyone had any problems like this?
:hmm:
Thanks!
03 cadillac escalade
:hmm:
Thanks!
Check the bulbs first if they ain't blown there is a junction plate under the right rear fender
Escalade EXT
yea i'm in the process of switching out all my lamps to LED to give her that extra element
Escalade EXT
Do you have a picture of your tail lights? Im king of apprehensive about switching those.
2006 Escalade
mikedyk43 said:
Post a pic of them here if you don't mind...
Ok I will give me a few minutes
Update I am having issues with the site not letting me upload the pic no clue why it is doing this arrg mike if I email you the pic can you try to upload it?
It says I am exceeding my quota for some odd reson I guess the pic is a higher resolution then I thought(I tried cropping it but no luck)
2006 Escalade
Sure I can put it up for you. I recommend using photobucket. It lets you store photos online and you can simply post the link from any photo you've uploaded and then this forum doesn't have to host the photo (no quota overages)
Escalade EXT
Discussion Starter #14
Thats nice on your trucks. I have a White EXT... trying to use my immagination but cant seem to do it. hmmm. Are the connections the same or does it require some electrical work.
They are plug and play(you just plug them in like a regular bulb) but they are available with red lens(which mimic the stock housings)
Here is the site I got mine from www.carid.com
Also thanks for helping me post the pics of my taillights
2006 Escalade
I'm afraid you will not be able to find LED taillights for an EXT. For some reason noone makes them. They are available for an Avalanche but the housing won't line up perfectly with the body mouldings of an Escalade. You can decide whether or not this would bother you.
You can try avalanche taillights(not sure if they a exactly the same)
Escalade EXT
Discussion Starter #18
yea if they dont fit PERFECTLY, it would bother me every day and i would probably cry a little every time i see em.
I am the same way I am going to have to replace one of the taillights as one of the LEDs is failing(thanks to the shop not checking the the ring around the socket and it bugs me like crazy
1 - 19 of 19 Posts
