1 - 2 of 2 Posts
05 sts 4.6
My left side mirror wont work when im trying to adjust it. Could it just be a fuse? help!! thanks
08 STS-4 N* 1SG, 08 DTS Luxury II, 04 Bonneville GXP N*
This will not be a fuse. The mirror is powered by the Driver Door Module. If the fuse was blown for this module, none of your door functions would work. The problem could be a few things from a bad door module to a bad switch or mirror adjuster. So the right side works fine, but when you switch to the left it doesn't? There is a center position. Is it possible that you may not be moving the switch all the way to the left?
1 - 2 of 2 Posts
