LED replacement for small "37" wedge-base bulb
1.2K views 6 replies 4 participants last post by  ORCoastGuy
2001 DeVille DTS. I had reason to open the center-console gear shift knob cover the other day, to retrieve something that slipped down in through the cup holder.
The small light bulb that lights up the gear position indicators has been out for some time, so I figured I might as well get it out to replace, if I could.
It is a small, size "37" (I assume that is the GE number) wedge-base bulb, with a blue plastic coating, to give the blue-ish appearance that matches the rest of the dash.
After 14 years, it's not surprising that the blue sleeve was brittle and adhered to the bulb. No luck in saving it and just slipping it onto a new 37 bulb. And without the blue cover, I am worried that an unfiltered white light will be too bright, and distracting to my eyes at night.
Does anyone have any experience and recommendation for a good LED replacement bulb for the small, wedge-base, size "37" instrument panel bulb??
Of course, I do see lots of them on eBay. But they all say they are replacements for multiple sizes, and the dimensions listed are not exactly the same. So I am just wondering if any other Cadillac owners of a 2000-2005 Deville/Seville have done the same thing with any of their instrument lights, and can recommend a good LED replacement that actually fit and worked well for them.
#2 · (Edited)
The sleeve is for color, not brightness. Install the bulb and see what it looks like. It definitely shouldn't. E distracting, it's pretty dim bulb and the light is "traveling through" the plastic part that the bulb sits in, being dimmed further.
If the color is off, grab some bulbs from the salvage yard and either install them and see if they work as is, or try to remove the sleeves.
An LED only projects light from the top. You need it to project light from the sides. You need an incandescent bulb for this application.
#3 ·
Thanks for your thoughts.
I know the sleeve is for the color, but filtering for color also reduces brightness to some degree.
I am also aware of the directional nature of the LEDs. I see more and more after-market units that include some diffusion of the light, rather than unidirectional. For this specific application, it's the only thing I would consider, for the reason you cited-- what gets lit up is the surrounding plastic piece. I get all that.
I'm in no pinch-- if I don't replace the bulb at all, I am fine with that. I just happened to be "next door" at the cup holder, and thought I would ask the world to see if someone has any experience with a suitable LED replacement.
