I do a lot of driving on backroads at night and also used race pro-rally so lighting is important to me. Sadly, my CTS is a model that came with halogen headlights so I’ve been looking into ways to improve on that. The two most logical ways to go are to convert to LED or HID. I’ve spent quite a bit of time researching the choices and finally decided to do the logical thing and buy both. I purchased them from Headlight Experts (who I am not endorsing, but seem to be among the more reputable conversion companies). It took months and several emails to get the HID kit delivered. I ordered all the options so with the 35W canbus and the warning cancelers the H11 kit came in at about $110. So far so good. I also bought aftermarket replacement headlight assemblies because mine were getting foggy and if modifications were needed I didn’t want to chop up the factory units. (more on this later) Some bench testing proved that the light was indeed brighter – and purer white than the yellowish halogens – but thankfully not bluish like the over 6000K units produce. The pattern was good too, with a sharp cut-off so as not to be offensive to oncoming traffic. Also, 35W is plenty. I think going to 55W is just looking for trouble.
Speaking of trouble, there is absolutely no way the conversion HID bulb assemblies will fit into the low beam location in the CTS headlight assemblies. I called the “experts” and they said “most people just leave the access covers off” which sounded like a terrible idea to me. Another concern I had is that the low beam lights on the gen 2 CTS also function as DRLs. – and - maybe one of my CTS brethren on the forum can confirm the rumor is that they run at something like 9 volts in the daytime to prolong bulb life. I should say here that prolonging bulb life is a good idea because you have to take the whole front end apart to change the bulb. (The dealer gets $350 for it …. Plus the bulb … of course). I also have no idea what happens when you try to run the HID ballast on 9 volts, not to mention finding a place to mount it and the other little boxes in the harness.
OK fine. The LED kit will solve all my (admittedly self-created) problems. They’re $110 with the warning canceler. I’m a bit Leary of LEDs for a headlight application (it’s not what God and Thomas Edison intended) and because it’s still kind of an emerging technology. Heck there’s moving parts for cryin’ out loud! Little bitty fans stuck to the back of the bulbs, um, I mean “Emitters.” How reliable can these things be if they need fans to keep ‘em from burning up? Yeah, I knew this going in but still… Oh and another thing – they don’t fit inside the headlight assembly either. Closer, but no cigar. (See photos) Even so, the light is pretty good, an improvement over halogen and good beam control too however the website claims of 3 times brighter light are ridiculous. Am I willing to butcher the brand new headlight assemblies to shoehorn these things in? Of course! My brothers and sisters on the forum need to know! Well OK maybe not, but I’m doing it anyway.
By comparing the standard H11 bulb to the LED unit, the additional clearance needed is around half an inch
Standard H11 bulb
LED Conversion “Bulb”
This can be easily achieved by cutting out the center of the access cover and gluing in an “extension” created by chopping off the top of a plastic chicken bullion jar. I am not making this up.
I have heard, but can not verify, that this will also work on sedans.
Using a drill press and circle cutter set to the OD of the jar threads and securing the cover to a block of wood the cover can be cut as shown. I make no claims about the safety of this procedure. It could probably be done with a hole saw or even by hand with some determination and a coping saw, but this worked for me.
Cutting the access cover with a circle cutter
Cutout complete
Enter the bullion jar. Just cut the top section off so that the threads and “shoulder” are all that’s left
Cut off bullion jar
Test fit the jar top in the hole
Jar top inserted in cover "inside" view
Outside view
Showing clearance for LED unit
Final modified access cover. (Note red jar lid for right side and blue for left)
Once everything is test fitted, glue the whole wretched mess together with a good quality adhesive. I use a product called Seal All, but stuff like E6000 will work fine. Probably don't use silicone, I'm not sure it's strong enough. Put the glue on the outside of the jar threads, screw the lid on and also create a fillet between the jar lid and the outside surface of the cover. Make sure the lid and cover are completely sealed to maintain the integrity of the headlight assembly. Let it completely dry for a day or so before mounting to the headlight assembly in case there is any outgassing (who knows how it might affect the LED emitters?) This also provides an opportunity to show off your handiwork to people who could care less and think you're crazy for doing it.
Modified cover in place on headlight assembly
Although I see no reason this can’t be done to factory assemblies as well, the use of aftermarket ones (I used PERDE units SKU:GM00529-HLAP) allowed me to be messing around with this foolishness while still having a drivable car. I also installed PERDE Solar Series Platinum H9 Xenon-Enhanced Halogen Bulbs in the H9 high beam position as long as I had everything apart (SKU:H9-65-BX2)
I still plan to add fog lights as described in the excellent post from rspreng on Feb 11, 2013 but for now at least I have somewhat improved lighting. Was it worth it? Well, it was to me, but not everyone is a picky about lighting as I am. Regardless, I hope some folks found this post interesting. Thanks to all of you for providing and contributing to this invaluable resource.
Standard H11 bulb
Cutout complete
Cut off bullion jar
Outside view
