Sunroof Window Height and Opening Fit Adjustment
1. Cycle the sunroof window from the full open to closed position.
2. Loosen the 4 adjusting screws (1).
3. There are 2 adjusting screws on each side of the sunroof window.
4. Center the window front to rear in the opening.
Notice: Refer to Fastener Notice.
5. Adjust the front of the sunroof window (2) from flush to 1 mm (0.04 in) (1) below the top surface of the roof panel (3).
Tighten
Tighten the front sunroof window adjustment screws to 5 Y (44 lb in).
6. Adjust the rear of the sunroof window (2) from flush to 1 mm (0.04 in) (1) above the top surface of the roof panel (3).
Tighten
Tighten the rear sunroof window adjustment screws to 5 Y (44 lb in).
7. Cycle the sunroof window through all of the positions.
8. Verify the sunroof window fore/aft adjustments.
9. Verify the front and rear height adjustment.
10. Readjust the sunroof window, if necessary.
