My sunroof had been leaking (not draining) for the past few months.
The fix for a sunroof that doesnt drain is actually quite simple.
In the trunk pull the side of the carpet back that isnt draining and look for the rubber hose that goes though the floor. Pull on it, it will come right out. Then if you see anyhting built up in it, roll it in your fingers, make sure you have something to drain it into or your trunk will get wet. The just push the hose back in once it drains out.
You back seat will now be water free next time it rains.
When I did this, I didnt know that it would sray out like this, so I got a mouth full of what tasted like 3 month old water, then you trunk got wet. But its not clogged anymore, there was a build up on the end cus the tube closes off on the end (i guess so no bugs make a nest in there or anyhting).
