I' owned my 06 XLR for about two years now and have noticed oil leaks coming from the magnets after I reintroduces synthetic oil to the crankcase, was Dino oil before, had to use two oil filters because of the debris in the engine. So I've looked at many supply stores on the seals that hold back that oil in the crankcase, but haven't been able to find any, even after talking to many parts attendants. They've printed out blowup details proving that no gasket is designed for sealing. I've found in my DVD mechanic information that a 15/64 alignment pin is needed to properly align and feed oil to the mechanism. All they state is that "Failure to align the camshaft position actuator solenoids to the camshaft position actuator oil control valves can lead to poor engine performance and engine component concerns". What are these engine components concerns? Plugs are need after alignment, does these plus have a part number? Also it states to "Apply a 2 mm (0.079 in) bead of RTV around the flange of the camshaft position actuator
solenoid". Is this the only seal to keep that oil from dripping out? To me, it shouldn't be because the magnets will get half way fill with oil, So now I'm reaching out for some help on this LH2 Northstar engine, because I'm at wits end. Thanks in Advance.
