with the cradle dropped, headbolts out, timing chains off, exhaust manifolds disconnected, etc etc etc... i thought i could finally pull the head off (front head). what i'm finding now is, while there is a fair bit of play, it still seems to be connected somewhere on the right side (water pump side). i've looked everywhere, and can't find any bolts or anything holding it on. i'm also applying quite a bit of force to remove it (while keeping in mind the safety of the gasket surfaces), so i doubt it's corrosion or whatever that's keeping it on.
what i'm thinking maybe, is that a part of the.. not sure of the term, but the large cast piece of metal, part of the cooling system i believe where the waterpump connects.. but yeah, that thing - maybe part of that protrudes into the head? do i have to remove this thing to pull the head? i'm hoping i don't have to, but will if it's necessary.
hope that makes sense, much thanks to anyone who can help-
