Originally Posted by elwesso
Its always going to be more safe to go directly to the battery than go through the harnesses.......
I dont think your going to have a problem..... I remember seeing something where you splice the low beams into the highbeam circuit, so that the low beams still get power when the highs are on....... Doing it this way IMO is very unsafe........
This kit looks golden!!!!!
In looking at the wiring diagram I see that the wire from one of the four posts of the relay is connected to the hot wire of the high beam,and one is connected to the hot wire of the low beam, both using scotchloks. One post goes to the battery and one post to ground. So when you switch to your high beams it activates the relay and allows the battery to power the low beams which at this point would normally be off.My question is what is the likelyhood running power to the hot wire of the normally off low beam could back into the system and cause a problem? This would be the deciding factor for me and my last question on this subject.
