1 - 9 of 9 Posts
2010 GT-R R.I.P. 09 CTS-V R.I.P. 06 STS-V & 05 CTS-V
What happens if i don't have the O2 special socket.....can i still take out the O2 sensors......
'11 CTS V Coupe
You can still get them out. Proceed with extreme care and you should be fine. On the other hand, an o2 socket is pretty cheap and available at most auto parts stores.
Cadillac Technician
none
A 7/8" wrench will work just fine.
The ONLY reason to use an O2 sensor socket is if you can't get a wrench on the sensor.
At least that is the only reason I use one.
04' CTS-V, 04' Escalade EXT
Piece of cake, reach up and disconnect the harness at the upper connector.
Remove the cat and the exhaust manifold and take them off; then you can install them before you install the headers.
Thats what I did and it worked just fine!
:thumbsup:
1 - 9 of 9 Posts
