1 - 19 of 19 Posts
okay i just changed my vehicle speed sensor today and then when i drove it got the code for engine knock sensor error(not sure if thats exactly what the code says) So where is the knock sensor at? And could i have unplugged it while changing the other sensor? Thanks
Unicycle
There are 2 knock sensors, they are in between... IIRC 3 and 4? they are mounted right onto the block...
... the speed sensors are part of the ABS, on the hubs right? I don't see how changing that could bother the knock sensors at all...
The VSS is on the tranny tailhousing, and if you have a 95-99 block, the knock sensor is <4" across from it. It's entirely possible you may have knocked the wiring loose, or disconnected it for some reason, and didn't put it back on. If you have a 93-94 block, your knock sensor is in the V of the block (next to the starter), also they went back to that scheme in 2000+ I believe.
dang i don't know which one i have, i know my car is a 94 but im thinkin the engine is a 95. but i found a loose wire so it must be the 95. I'm gonna check that out. I'll let ya'll know.
The motor I put in my car was a 95/96. It had the knock sensor on the back of the block right in front of the trans. It screwed in to what looked like a bolt hole. I had to drill and tap a boss in the valley to install the knock sensor in the correct position for a 97.
Based on the fact that you got a knock sensor code after changing the VSS I would look for wires/connectors that look to be connected on the lower part of block on the back side of the motor.
Bbob would know this right off the top of his head.
mastertech said:
95 to current has the knock sensor in the valley under the intake, I think 93-94 is on the back of the block.
I have a 95. It's directly across from the VSS sensor. Blah, now you're confusing me! I'm starting to have doubts as to where it was on my 94... Maybe it was in the same place? I KNOW y2k models are under the intake.
Discussion Starter #10
okay well i must have unhooked the knock sensor while i was pulling the speed sensor out, because the knock sensor is up and to the right. I don't think i could have got the speed sensor out without unplugging the knock sensor.
I'm a Cadillac Fanatic!
My memory is fuzzy but I could have sworn that the knock sensor was on the outside of the block on the right hand side (rear side) of the block about mid way down the engine on the 93/94/95 Northstars.
The knock sensor was relocated to the valley under the intake manifold in 1996 and has been there ever since.....
I am still trying to track down a good service manual for my 2000 STS so I'm not sure HOW to change the knock sensors. The car is stalling and sometimes requires excessive cranking to start. The error code is P0385 which is the circuit B knock sensor. Seems to make sense to change both at the same time so I picked up both of them. Now I'm stalled until I figure out how to 'expose' the knock sensors.
I know it is not that difficult, but what do I need to do to get at them and switch them? Should I just wait until I find a good manual or is it fairly easy to do this? :hmm:
Thanks.
Thanks.
Have you ever changed the crank sensors to the updated versions..??? If not, I would definitely replace the crank position sensors before touching the knock sensors. Unlikely that the knock sensors would cause any sort of stalling or poor performance complaints like you describe.
The 2000 crank position sensors have been documented to cause stalling, no start and other driveability problems without setting any crank sensor codes. There were quality issues from the crank sensor supplier in that generation of part which mandated a superceded part number. Get the latest sensors from the dealer and replace them first. The crank position sensors are on the side of the block/lower crankcase on the LH or front side midway down the engine above the oil filter adapter. Just R&R them. Once the car is in the air and the plastic blockout panel from the rad support to the engine cradle is removed the crank sensors can be accessed by reaching above the engine cradle crossmember. Nothing to adjust or set....just disconnect the wire connector, R&R the sensor with the one bolt that retains it and reconnect the wires. Do both of the sensors.
If you do decide the replace the knock sensors you need to lift the intake manifold up to access them. Remove the 10 perimeter bolts holding the manifold down and lift the manifold up enough to reach the sensors in the valley of the engine. All the seals are reuseable and there is no coolant in the manifold so it is really not that big a deal to lift the manifold up.
On the 94 it's on the back of the block. How do you go about replacing it? From the top of the engine or come from underneath?!
I just put a new starter on a 95 northstar. Can anyone tell me what if anything should be in this hole. There was nothing there when I removed the intake manifold. I also have a connector that I have been trying to find where it plugs into with no luck so far.
1 - 19 of 19 Posts
