'05 CTS-V
I tried searching for this but no luck so far. My lock/unlock buttons will not work (except for very rare occasions). The trunk button works perfectly every time. I replaced the battery and still no luck. I only have one fob. If I can't figure it out I guess I will have to go with an aftermarket system (which I don't want to do).
Car is an '05 V
CTS V (05) BMW M-Sport Touring (03)
Darkman should charge a commission..I am a short time board member/owner and am amazed at the help he supplies to everyone that needs it..I was and still am an M5 board member and the degree of knowledge and help available on that board is excellent and our member Darkman certainly elevates this board with his know how and willingness to assist others..
05 Stealth Gray V
Good info as usual!
My keyless barely worked until you got right up to the car and only then when you hit the remote 20 times. Before trying batteries and keypads I got lucky and found a loose connection on the center antenna lead on the rear window. Bent the tabs in a little to tighten it up and now it works from 20 yards every time...
