So my second issue that I have been trying to figure out is my key gets stuck in the ignition when trying to remove it ONLY.
The details:
New battery and verified good, no dash lights stay lit, no theft light, there is nothing wrong or out of the ordinary going on. Car starts and runs perfect, switch rotates to all positions perfectly, I even pulled the key cylinder and cleaned and lubed it. So it is not the battery, not the anti-theft, or other issues that I am finding on the forums. There are NO symptoms.
No matter what, when I turn the car off and turn the key to the "OFF" position, it does not rotate all the way. I have to press the manual release button under the console to let the key rotate that little bit more to actually fully release the key. I have also sprayed it and cleaned it with lock specific cleaner and lube, etc. but no go.
I do not want to dis-assemble the whole column, but I can takeoff the cover and play around. But I would like to know if there is a solenoid, or whatever makes that switch release. It feels totally manual.
The details:
