93 cadillac sts seville
hi guys i keep blowing my left tail light fuse on my 93 sts. i keep losing the dash and instrument lights at the same time. the new fuse is fine till i take the car out of park,into reverse then boom there goes another fuse.and no more dash lights or left tail lamp. i have already replaced all left bulbs and sockets, as well as both sides reverse bulbs and sockets .what to do? thanks in advance for all input.help!
Discussion Starter · #3 · (Edited)
thanks i'll check the grounds in trunk first. i noticed a grey wire that has been disconnected in the gear shifter cig lighter area due to an aftermarket alarm which was installed by the previous owner. also there is a black wire disconnected in the same area. the grey wire is now routed into the aftermarket alarms harness. i noticed this when i removed the aftermarket stereo that had been sloppily installed by the previous owner. i returned the decks harness to stock. what are these black and grey wires for? could they be causing left tail fuse to blow once car put in reverse?
'02 ETC CE, '04 CTS-V, '04 XLR, '13 XTS Platinum
Look for a short in the reverse lighting circuit, since activation of that circuit seems to be blowing your fuse. The advice to start with a schematic is an excellent way to start. Look for a ground on the fused side of the circuit whenever your back up lights are energized (shifting into park --which energizes them briefly and of course, reverse.) You'll need a multimeter or lighted circuit tester to accomplish this.
CC
