Hello everyone, I just purchased my first Cadillac, a 94 Deville Concours with 206,000 miles on it currenlty. It has a bad transmission so I thought, but through research I discovered that it apparently has a bad solenoid.
I would drive fine for about 5 miles then lock itself in second gear and not shift again until after I shut the engine off and restart it. So I checked the codes and found on this forum that it was the shift solenoids.
I went to the junkyard and took the complete valve body out of another transmission and put it in mine. However now it goes into gear and slips badly when you try to take off in the forward or reverse. Could the valve body I got be bad, or did I put something together wrong.
I was thinking of trying another valve body as it didn't slip before I did this.
Anybody ever have this problem?
