Are you sure this is the best you can get?
yeah i called around all weekAre you sure this is the best you can get?
yeah from what i saw and i look over the entire car only thing wrong with it is the cracked winshield but i can get one for 100 from a junk yard and then like 50 to have it put on i think maybe 80 not sure$6k grand isn't too bad; i've seen a few STS's going for the same price with similar mileage but you're better off going with this car than that Deville.
Good luck with the car.
oh no i didnt mean there where codes on no codes on now im saying isnt there a computer or somthing that will make a code come up or a message center say that its time for a OIl change or a service once that comes on how do i reset itBefore buying that car, you need to check the codes and see what that service light is. It could be something minor, but it could be something extremely costly. Look at the top of the Seville/Eldo forums on info about how to pull codes and reset them. The code reader is built into the car and will give you any information about what is wrong with the car.
Your new car has no plug wires. It uses individual coil-on-plug ignition cassettes, one on each cylinder bank. Have your dealer check the GM VIS system to find out if the plugs were changed at the recommended 100,000 miles. They are ACDelco #41-987 Professional Platinum plugs. If you pull the cassettes, no easy job, especially for the rear bank, check the coil/plug connector boots for carbon tracking and sealing ability. There will be some small amount of oil on the lower plug insulators: the wells are sealed by O-rings in the cam covers and tend to weep a bit. Not a problem.
Use a WIX panel air filter, #46302. More surface area = no restriction. You might find that Pennzoil Platinum synthetic (Shell/Pennzoil/Quaker State company) is somewhat less expensive than Mobil 1.
GM is now using DEXRON-VI synthetic transmission fluid, 100% backwards-compatible with DEXRON-III. Have a GM dealer do the service as part of a spring special, along with the coolant, and then you'll have a dealer to fall back on if you feel something is not right. DO NOT do a "tranny flush". Many good reasons for you not to - let a dealer do it correctly. BTW, the 4T80E is a dry sump transmission: there will be no fluid on the dipstick with the engine off. It MUST be checked with the engine hot, running, in P. DO NOT overfill.......and, if you remove the air intake tract to get at the dipstick and then try to start the car, it will not run and will set MAF and mixture failure codes. Look before you leap........
Please, before you begin to tear into an unknown car and its unique requirements, come back and ASK !!!
iowaseville has no plug wires, either.............
cool thanks that is what im going to doSLS uses a 275 hp VIN Y engine with a 3.11:1 final drive. STS uses a 300 hp VIN 9 engine with a 3.71:1 final drive. The hp figures varied a few hp up and down over the model runs, but stay relative. The 2000 engines saw a lot of internal changes to the earlier design, and are generally considered to be better engines, if not rated quite the same.
Stick with the 2000. It is a tad more sedate than the STS, but it will return better gas mileage (highway) and had a statistically better chance of avoiding the head gasket failure of earlier engines.
