2001 Seville STS
Hi All,
Yesterday I had to jump start my 01 Seville STS, so I went under the hood and connected the cables just as the manual said.
Then started the donor car and let it run for a minute. Tried to start the Seville. Nothing. Zip.
I then pulled out the back seat and went straight to the battery and connected it up. Bingo! Started first go.
Is this normal? Anyone else experience this?
Cheers!
Cable connections at the body ground (under the rear seat) and at the positive end of the underhood fuse/relay box.
........... or poor jumper connections at the underhood connectors.
When you connected the underhood jumpers and turned the key ON, what was the voltage readout in the DIC ? With another car connected/running it should have been over 13.6 volts, preferably 14.2+.
2001 Seville STS
Once I had the Seville up and running, the DIC readout was 14.2 whilst idling. During driving it is (usually) 14.6 Volts
I drove the car for an hour or so with no problems.
I agree that the cables were difficult to connect directly to the battery as there isn't much room under there. Much easier under the hood, but I'm just glad I got it running. Of course these things always happen when you need to be somewhere !
