Since GM pushed (over the air) an update for recall Program #N192217490 (issued: Jun 04, 2019) to my 2018 CTS with CUE-3, on occasion the Nav app does not load properly. It does not launch upon vehicle start when on the home screen split view (the one where audio information and a small nav screen are shown which is called the "porch" view), or the full screen Nav view is blank after selecting it from any screen. Killing the app once or twice usually gets it to load and work properly. At the same time, occasionally the USB media appears to be re-indexing, something it only did when the USB drive was plugged in for the first time prior to this update. If the vehicle is turned off with the full-screen Nav showing, it usually starts up properly when the car is next started.
After extensive GM testing on the vehicle (where the problem was reproduced multiple time allowing the collection of log data for analysis), I'm told that GM Engineering and the supplier analysis has shown that the symptoms are directly related to how my USB media is organized, the amount of data and size of the device, and how this stresses the system at start up following the last software update which occurred in July. So clearly it is a resource issue.
The USB drive is a 128 GB SanDisk drive with approximately 6,500 files, organized by artist in in about 168 folders under the root and then by album subfolders under each artist folder. This is the same drive and file organization that was used prior to the latest software update without incident since the car was purchased in July 2018. So clearly something in the latest software is the root cause.
Has anyone experienced this type of behavior? I'm trying to gather additional information to compel GM to fix this problem that they created with the latest software update.
