1991 Eldorado (Gone) ; 2001 Seville SLS (RIP) ; 2005 DeVille
What are you thoughts on a Jasper engine verse an OEM? My main wondering is if Jasper has done anything to activly eliminate piston slap in these engines.
The kicker is, I can get either engine for similar price. Either from gmpartsdirect, or the local GM dealership that I can get %10 over cost.
I'm mainly worried about piston slap and if the OEM engines will come with the redesigned pistons.
Other pro and cons?
Dustin
Do a search for JASPER. Some one just had a post on it and it was not in Jaspers favor.
'64 Cpe Deville, '94 Concour,2012 Prius C, 2010 RAM 1500 red
Is the OEM engine you refer to a new Factory crate unit ?
What kind of warranty on a Jasper N* 4.6 engine?
Just a year ago I was hearing that Jasper did not and would not reman a N* because of lack of availability of bearings and the stripped headbolt threads /gasket issue.
Some one can correct the shortcomings in the wonderful N* , it is technically possible and maybe Jasper now has a heads up on improvements.
Please keep posting and let us all know what you decided?
