For those who are interested in Jacking their ATS-V with a floor jack and jack stands, GM has made it difficult.
I have been researching before my car arrived, and today completed a brake fluid flush and pad exchange using floor jack, magnetic Jack Pads and JackPoint jack stands.
I initially had the dealer print out the service manual directions for the jack points. Below is the picture.
The document states, "Place the front lift pads on the rocker outer panel weld flange" and "Place the rear lift pads on the rocker outer panel rear cradle brace. "
For the front, here is a picture, pretty sure they are referring to the pinch weld at the arrow.
The problem is the pinch weld is inset higher than the adjacent rocker panel, so you cant use the standard hockey-puck type pinch weld adapter. (though you might if you saw off the edges so it is narrower).
So I found an adapter online that is made for Camaros and other cars, very nice product. Website is ZL1addons.com. I used the premium magnetic Jack pad. (I have no financial or other relationship with the company- just nice product). It fits the pinch weld perfectly, though is still inset.
So a standard flat hockey puck allows the floor jack plate to contact the base of the red Jack pad only. In the picture below, the jack pad is on the pinch weld, resting on a hockey puck on the deck of the JackPoint jackstand. (Another nice product - I used the recessed pad as the pinch weld pad would have lifted the rocker panel, not the pinch weld).
For the rear, I think the service document refers to the black brace with two edges (yellow arrows). Not sure how you use that, unless you set a floor jack pad across both edges. I thought that would bend. The adjacent pinch weld (white arrow) with the magnetic jack pad worked well.
The rear pinch weld is less inset, so easier to access.
Would welcome anyone else's experience, post if you have any different ideas. The pinch welds with Jack Pads worked well, though does require lining things up rather precisely. Even having the car up on stands, I can't find any easier places to floor jack from, not the mention a place to put standard jack stands. I know someone described lifted the front in the middle with a wood block - my floor jack would never fit below the carbon splitter.
