21 - 21 of 21 Posts
2014 CTS Coupe 3.6 RWD Perfomance Pkg, TriCoat White Diamond
Yes the fuel line is junk. I got the same thing. When you look at the actual fuel line you will see that it is cheap and will fall apart. The steel wool is not necessary either. Otherwise it is pretty much what is on my car.
Thx!!! You're great help. I have a NAPA store a couple of blocks away from me. Any comment on reusing the OE hosing to the "In" port? I'll need a to leave a couple of inches for engine torqueing, correct? Did you remove your manifold and what are the torque specs? if not, do you suggest it to clean out the excess oil? I'm not sure where the O-Rings installed.
21 - 21 of 21 Posts
