2007 Thunder Gray CTS-V
I did a quick check of camber and toe on my new (to me) '07 -V and found the front end a little out of adjustment, which is what I expected, since the steering wheel is off just a bit. So after responses to a recent post which Darkman provided the alignment instructions, I found I needed a J 45845 tool to move the lower A arm on the front suspension. Not wanting to pay $120 for one, I built my own, using 5/8 inch, 4 5/8 nuts, all thread, and two Category 0 to Category ! bushings from Tractor Supply. I welded short pieces of all thread, after grinding a groove in them, on the bushings and A little welding and the finished product is below:
2007 Cts-v 2007 Cts 3.6l (SOLD)
Nice work. I've work in shops for years and we have always used home made camber tools. With a little thought and timr you have a $100-200 tool for $10.
here is a better photo of the business end of the tool. I chucked the short piece in a drill press and used a grinder to make the groove.I used the grinder to "chisel point" the end that was welded to the bushing.
Greetings, do you still have that wonderful tool that you created and would you be interested in selling me one
2005 Base CTS work at Pullen solenoids Glass Factory for 36 and a half years
They have not been on the Forum since August 1st of 2015 so I doubt you will get a response.
Roy
2004 CTS-V
I have one of those tools for setting front camber. Funny thing is when I went in for alignment the tech got all pissed with the tool and just used a large screwdriver he had to move the control arm around and got the alignment done as I had requested. I did a modified street setup with more camber without sacrificing too much castor and 0 toe.
