So I finally got around to stepping up to larger tires. My old tires were bald, and I ran over a nail the other day so I decided it was the right time. I was going to go for some really nice rubber but decided to go middle of the road performance all season. I got a set of BFG G-force Comp TA KDWS 255/50/ZR17 tires. They definitely look cooler, which is a side benefit. I just drove it from DC to Massachusetts on them. They are smooth, and relatively quiet which is nice. Unfortunately with a car full of luggage I didn't have much of a chance to throw it around. On one sprint while chasing a Celica GT I ran it up to about 110 or so on a stretch of open, winding highway, and it fel A LOT more sure footed than it used to. Driving around town it's more responsive. Hopefully tonight I'll get to take it out and really thrash it. I can set up my G-tech and see what it pulls in a parking lot skidpad. All in all I would say stepping up to this tire size is definitely worth it. Especially if you want the car to feel a bit more nimble. Next I plan to get thicker swaybars, which I think will really make take it out of the boat category and make the car a decent handler.
Scott
Scott
That's a significantly wider tire and only a little taller. The speedometer/odometer shouldn't be off by much. As long as you don't rub on anything, you should be ok.
Good luck.
I should have mentioned. I calculated the size I wanted before I started all this. The sidewall height on the new tires is 1.4 percent off. Not significant enough to have a problem. I also made sure to test fit a pair of these tires before ordering mine. I got the guys at the local NTB to put a set on and let me make sure it doesn't rub. I was quite sure they would fit before putting them on. This was confirmed by a fitment guide that one of the shops had. It listed this size tire as a suitable replacement for DTS's. The tires fit fine, and the speedo should not be noticeably off....they aren't actually that accurate from the factory (often as much as 6 percent off) so I'm fine. The change in handling is well worth the effort, and it's a straight up upgrade.
Scott
i just got my 16x7 inch deville wheels for my 90 coupe, i still need to get tires for it, i was thinking of getting 225/45/16 but how wide can i go? iam not a big expert on tire size and stuff.
Banned
1995 ETC, 75 Deville, Cad500 powered 73 Apollo, 94 Mark VIII
The stock 15" diameter, 9" wide wheels carry tires that fit the wheel, but can rub on the inside of the wheel well. So I won't be getting anything larger, and no matter what I do I'll still have the boat feel of the 5200# deville.
