94 Fleetwood Brougham
My 94 FWB has some very sloppy shifter linkage. Like, when in OD, if I moved the shifter up, I can get the needle between R and N. But all the way down is OD. If in D, then up to between N and OD to rest down in D. So when shifting from D to R takes some doing to keep from overshifting into P or to just sit between gears.
Is the linkage a cable to the trans, or is it like my 80 T/A, where if loose, it will do that? I haven't had a chance to get under it to look (it is 10pm when I get home...) and weekends are always busy. So I would like to get an idea if this is common and is it an easy fix?
The shift rods under the hood seem ok, nothing obviously wrong there. I haven't had a RWD Column shift car since my 76 Olds and it was fine.
Thanks!!
'80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
Check to make sure that your frame bushing is there and not stuck.
Hmm! I forgot there was one there, my 76 had it, but my 80 T/A doesn't (cable shifted).
I will be under it tomorrow. Danke!
